jet1012 1 Posted March 7, 2016 HI I am hoping someone can help. I have been going through a ton of posts, can't seem to find one with the same issue. I have LP II and using Signblazer, I have had a lot of issues and thought I had finally was good with everything. I am finding that no matter what size the image is the end of the image the cutter will "lightly" miss a small spot of the image, for example a 12x30 quote and it just grazed the about .5" of the design. I can see the line, but it is not fully cut for weeding. I am assuming this a setting issue, but I am not sure where to start. Any ideas? (This is only happening at the end of the image) no matter which way I am cutting. Thanks Share this post Link to post Share on other sites
MadHatterGraphix 1,258 Posted March 7, 2016 Is it in the same area? check the cutting strip to see if its damaged or coming up. Make sure the nodes are attached at the end of the cut. Share this post Link to post Share on other sites
