Signs and Designs 17 Posted March 6, 2016 I can not remember where I went and turned on. Cutter (Graphtec Ce5000-60) return to start. When cutting, the cutter will finish cutting and then return the vinyl back to the beginning, where is it I go to change the setting of the cutter or VM, to cut the graphic and stop right there on the end and not return all the way back to the beginning. Thanks in advance Bob ( I hope I explained it right..) Quote Share this post Link to post Share on other sites
VinylMaster 148 Posted March 6, 2016 This is explained in the manual. To access the manual and with the software running and a page or document open, click the Help menu and then select Help Topics. In the Window that comes up you will see a column of help books on the left side which are the same as chapters in a book. You will also see a Keywords tab that displays a list of topics that include any keywords you type in. Type: Advance After Plot If you experience a technical issue please lodge a ticket at: http://future.support Quote Share this post Link to post Share on other sites
Signs and Designs 17 Posted March 7, 2016 Thank you will look Quote Share this post Link to post Share on other sites
