Guest Jerry TorresIII
Vinyl Master Cut doesn't Import Image
Darcshadow, I've had the same sort of thing but rather than missing nodes it was extra nodes on lower layers.  Almost like a square was node A1, A2, A3 and A4. When a copy was made it became B1, B2, B3, B4 and then moved.  But when VM or Explorer see it it's reading A1, A2, B3, A3, A4, so the middle of one side took off in a funky direction.  Deleting all the extra layers and objects gave me back the original image.
Guest Nick
I’m having problems with cutting what I import? Do I need a specific file name?
first, register for the forum, it's free.
second, your cutter will only cut vector images, so that's what you need to be looking for.
The only files that will cut are vector format.  Outlines. When you but them on wire frame mode you will see the outlines.   Vectors formats are .eps. .ai. cdr. and others.
and it involves more than just converting the file to that format - vector files are made with point, lines, arc, unlike raster files you might be familiar with that are made of pixels
If  you're unsure what vector is, then Google vector vs. raster.
2 minutes ago, TechGurlAZ said:
I am experiencing the same issue. It is not about a file format, it is that when I click on File>Import   nothing happens. I do not have the option to choose a file. I am fortunate that it does not lock up my computer, like others seem to have experienced.
I just downloaded the software today. It is VinylMaster Cut V4.2 . I was considering upgrading, but if the most basic functions on the original software do not function (and seems to have been a problem for 4 years), I don't know that I want to sink any more money into this.
Hundreds of people use it with no problem including me.    When you click import does it bring up the box to select an image or nothing happens?   What type of file are you trying to import?  What os are you using?
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
