storm2313 25 Posted February 26, 2016 If you perform a fill on vectored graphics, and group a multi pieced version of a graphic, you have a white line showing through the fill. Will this be printed if you print the graphic with the fill, or is it just the software letting you know where the separate piece of the vector is? Thank you. Quote Share this post Link to post Share on other sites
signyouup 178 Posted February 26, 2016 Check to see if the vector has a "stroke" or "outline" depending on your software. Quote Share this post Link to post Share on other sites
dcbevins 340 Posted February 28, 2016 I know in CorelDraw there are instances where the objects are buttressed next to one another, with no gap, but if you are viewing with Enhanced view turned on, a 1 pixel white gap shows. This is an antialiasing relic. If you set the view to normal, the gaps vanish. In Draw you can export as a bitmap, say png, and disable antialising. The resulting graphic looks fine. Maybe Vinyl Master has a way to export as bitmap with antialising turned off to see what you might expect, or even better a way to turn antialising off on your display. Quote Share this post Link to post Share on other sites
VinylMaster 148 Posted February 28, 2016 Not is shouldn't print... to test, export it as a bitmap and view it in Windows Paint. Quote Share this post Link to post Share on other sites
