houstonwehaveaproblem 0 Posted February 26, 2016 I have an email in with us cutters right now, just waiting on a reply. While I wait I would like to find out if anyone else has been experiencing the same issues. I am not new to vinyl cutters, I have been using them the last few years so this isn't my first set up. I followed all the directions on start pdf too, just to be on the safe side. Up until last week I have been using a laser point 2, with SCAL3 e Now on with the problem. the machine is set up. I have vinyl master installed. correct driver is installed. I open an SVG saved from AI, try to cut and it does not cut correctly, it is 2'x2' and instead of cutting across the cutter it is making small cuts at the origin then spooling 2' of material and making a few small cuts and bouncing back and fourth. I cancel the cut try and rotate the image a few different times and nothing is working. I then say screw it and let it go. after about 8-10 minutes in the cutter starts to overlap the image and I have to cancel the cut. I try tracing the image in vinyl master and I get the same effect. keep in mind this is the same file I've used in SCAL over the past year on the laser point. I try all the calibration options in vinylmaster multiple times. I give up with vinylmaster and open SCAL 3. I load the Titan 2 into "my cutter" and bring up a SCAL file that I always use and know it to work on the laser point. The cut order is much better and it seems like it is cutting smoothly. The issue is when I go to weed my project there are gaps in some areas and overlap in others. I cut a second sheet before I picked the first, the second has the same issues however the gaps and overlaps are not in the same place. they are located in different areas. I am beginning to think it is the offset of the cutter or possibly the cutter is a lemon... I'm not sure, hopefully USC will fix me up and I can get back to business. If anyone else has any tips Please help me out. Being without my vinyl cutter feels very weird, and I have orders coming in that I have to refuse or have an extremely log wait time. Share this post Link to post Share on other sites
xpaperman 719 Posted February 26, 2016 So, just to try and fully understand the problem..... You just got the Titan 2 and are trying to use it for the first time? Or have you been using it and it just started acting up? If it's your first time/initial set up, then I bet something is just not set right. Is this also your first time with Vinyl Master? You say you have been using SCAL, with success. Have you tried SCAL with the titan? (This could isolate the the issue to cutter vs software.) I am probably not the best person to help you, there are others here with way more experience, however I seem to be the one that stays up the latest...... That being said I will put out a few suggestions and if we don't get it fixed.... there will be tons of help for you come sunrise! Share this post Link to post Share on other sites
busterbay 326 Posted February 26, 2016 Make sure the adjustments on the blade holder are tight. Mine loosened up when new and was giving me all types of fits before I discovered it. I also overcut everything by 1mm. Have you completely eliminated your cut file ? When I export from Corel I often find things in SCALP that I didn't know were there so I make a habit of using Union on all SVG imports as weld doesn't always find the overlaps. Share this post Link to post Share on other sites
houstonwehaveaproblem 0 Posted February 26, 2016 I used scal with my laserpoint the last few years. Just upgraded to the Titan 2 and vinyl master. I imported a graphic into vinyl master. I tried a svg, tried to trace the image from a png, also tried using an Adobe illustrator file. They imported fine. Looked good in the program. Did not cut well. I tried recalibrating the machine numerous times with no success I opened my old scal software, loaded an old project which works 100% on the laserpoint and does not work on the Titan. From what it looks to me it is the machine. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted February 26, 2016 So maybe you should be contacting Vinyl Master and Uscutter,,tech support...Uscutter is open, Call them. Share this post Link to post Share on other sites
houstonwehaveaproblem 0 Posted February 26, 2016 I work full time not vinyl. So calling is out of the question till Monday. I do have an email in with USCUTTER. Waiting on a reply. Thought I would try here and see if anyone else experienced this. It's easier to check my messages and email than to wait 30-1 hour trying to talk to someone when I'm not next to my machine. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted February 26, 2016 Well they are on Pacific time if that helps.. 6:15am - 4:45pm PST Share this post Link to post Share on other sites
