Lou 0 Posted February 25, 2016 I have SignBlazer and a MH871. Recently, every time I cut a sign I have to shut down and restart because the program will not send the next thing to cut to the cutter. Any suggestions on how to fix this? Thanks in advance! Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted February 25, 2016 Could be a lot of reasons...Static, memory overload, being on USB,. ,Always turn your cutter off before doing the next job..Very low memory in that cutter. Those value cutters use a cheap chip in USB, not true USB like higher end cutters. Pick up a Tripplite Keyspan Adaper, that is the brand name and the only one that will work with a vinyl cutter. Share this post Link to post Share on other sites
Thunderbolt88 0 Posted February 25, 2016 I have the same problem on my machine too, but what I do is I turn on the cutter machine first before I turn on my computer, or I restart my computer before I start any cutting. Mz Skeeter is right also too much memory, and if you have it connected to the USB it cause signblazer to crash and not cut. Just make sure you save you work turn on cutter restart the computer and cut. Works for me Share this post Link to post Share on other sites
