Guest Curtis
Uploading
Guest Curtis
I just received my new cutter yesterday that came with Vinylmaster. My old software was Signblazer elements. My question is, is there anyway to upload the decals I've already made into this new software? Thanks!
Hey there Curtis, congratulations on the purchase.
What cutter did you obtain?
You can continue to use SignBlazer if you want, by the way.
As for your question, there is a feature in SignBlazer called EXPORT (File menu) ---  choose .eps as the format.
Then, just IMPORT that .eps into your VM.
Remember that text will often reproduce poorly and you might want to re-type text in VM.
Thank you slice&dice! I bought a 25" SC from US Cutter. Now I just need to figure out the printing on vinyl part so I can learn how to use my contour cutting feature! lol
Guest Bridget
Thanks So much!! I recently encountered the same issue and this was extremely helpful!
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
