emil_losinj 0 Posted February 11, 2016 Hi! I have old CT630 and a big problem: When I try to cut some logos (not all, just some), it starts to cut them through the letters or my design! I usually make a design in Corel and cut it with SingCut or SingBlazer, but on some desings it starts to cut letters like it try to cut negative decals, like a frame... and ruin some letter... Please check the pics below, it might be better then my description Tnx, Emil Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted February 11, 2016 Post up the vector file, so we can look at it. The real file not in your software. not a jpeg. Share this post Link to post Share on other sites
emil_losinj 0 Posted February 11, 2016 Here it is . I have made same as this only diferent phone number, also in Corel x7, saved in .ai and cut it without any problem. Tnx 800x300_sve_2.ai Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted February 11, 2016 Your cutter is going to cut exactly what it sees. All of those lines are there in your design...They are created there.. So it's going to cut them. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted February 11, 2016 Did you trace that or something? What happens if you weld them before cutting? Share this post Link to post Share on other sites
emil_losinj 0 Posted February 11, 2016 Tnx, now I see them in Corel... But how do they get there?? I usually write a text, convert it to curves and that's it! Once I have made a screenshot of design, convert it back to vector (with Vectro Magic), and still had the same problem. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted February 11, 2016 If your making it in Corel. it is a vector,, No need for Vector Magic, Save it .. And Import into Signcut. Corel is your vector program, no need to trace it to make it a vector....Your welcome. Share this post Link to post Share on other sites
emil_losinj 0 Posted February 11, 2016 I know, I was only trying to avoid the cuts. Thanks for replying, Emil, Croatia Share this post Link to post Share on other sites
emil_losinj 0 Posted February 11, 2016 Now I have saw your post for welding... No, welding does not help... Share this post Link to post Share on other sites
JP Auto N Design 36 Posted February 11, 2016 I have this same intermittent issue with Corel to Signcut. Still haven't figured out what causes it. The work around I use is to break everything apart in Corel then open in Signcut. The centers of certain letters (O's, D's, B's, etc.) wlll appear filled in, but it still cuts normal. You can view it in wireframe mode after breaking it apart to verify the centers are still there. Share this post Link to post Share on other sites
dwp99 283 Posted February 12, 2016 Hi!I have old CT630 and a big problem: When I try to cut some logos (not all, just some), it starts to cut them through the letters or my design! I usually make a design in Corel and cut it with SingCut or SingBlazer, but on some desings it starts to cut letters like it try to cut negative decals, like a frame... and ruin some letter... Please check the pics below, it might be better then my description Tnx, Emil Emil, I imported into Flexisign I was able to weld the image and get rid of the lines. Hope this helps Doug 800x300_sve_2.ai Share this post Link to post Share on other sites
emil_losinj 0 Posted February 12, 2016 I think I've found the problem. Only designs made in Corel 12 have this lines, others made in Corel x7 are good. I was using SingBlazer and I could only import .ai files saved from Corel 12, that's the reason why I have lines only through some designs. Tnx for your help. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted February 12, 2016 I think I've found the problem. Only designs made in Corel 12 have this lines, others made in Corel x7 are good. I was using SingBlazer and I could only import .ai files saved from Corel 12, that's the reason why I have lines only through some designs. Tnx for your help. Great, glad you got it figured out. Share this post Link to post Share on other sites
