gili 0 Posted January 26, 2016 hello I am new here And enjoys the forum very Your recommendation I bought the cable TRIPP LITE How authors? Both have prominent Thread Thank you (Sorry for the language I assisted on Google translate) Share this post Link to post Share on other sites
darcshadow 1,625 Posted January 26, 2016 You need a serial or a null modem cable to go from the Tripp Lite to the cutter. Your cutter should have come with a cable, connect it to the Tripp Lite adapter and your cutter, if not, the manual should tell you what kind you will need. 1 Share this post Link to post Share on other sites
slice&dice 2,450 Posted January 26, 2016 Shalom Gili, This is what you need between the tripplite adapter and the cutter --- http://www.ebay.com/itm/6ft-DB9pin-Male-Female-Null-Modem-Cross-Nul-wired-Serial-RS232-Cable-Cord-Wire-/121863300921 1 Share this post Link to post Share on other sites
