diverse designz
two machines
I have a uscutter with sure Cuts A Lot Pro 4. I am interested in purchasing a second cutter and I'm curious if I can run both cutters of 1 software installation
You should be able to but probably not at the same time. I am not a Sure Cuts owner (any more) so not 100% but SHOULD
You have a single computer, and want to hook up TWO cutters to it?
Doesn't seem reasonable to me.
Get a second computer and dedicate it to the second cutter.
(USCUTTER, by the way, is providing VinylMaster software now for purchasers of their mid-range machines --  SC, LPII, Titan)
IF....IF I were to do so would there not be a collision USB/Serial issue....I NOW have 2 LP II running and each on its own machine BUT...I have in the past ran the SAME 1 piece of software on 2 different systems so as above has stated it makes logical sense to put together a 2nd system and have independent operating systems....I am soon to try a LP II on a Mac Pro but not yet till I do my home work....
Maybe they found a cutter cheap. Not everything has to fit your expectations.
