kimbo 0 Posted January 23, 2016 Hi! I would really like to be able to print on HTV, but is there a reasonably priced printer that anyone uses? Also, for the Sisier ColorPrint easy, you can use eco solvent ink, can you also use that with transfer papers? Thanks for any answers! Share this post Link to post Share on other sites
Wildgoose 4,200 Posted January 23, 2016 limbo if you look in my signature you will NOT see a printer (eco solvent or solvent) listed. They are only reasonably priced to the company who sells them! Very pricey and that is just the start because there is a lot of maintenance and potential costly repairs. Basically I talked myself out of them about 5 times in as many years. I just hire it out to Dakotagrafx on the forum. He does a great job and ships reasonably. There are several others on the forum who do likewise. If I ever went big time with a brick and mortar full time shop I might consider it then but it doesn't fit my business profile at this point. From what I found the Roland BN20 is probably one of the best less expensive options out there, just limited width being an issue. 1 Share this post Link to post Share on other sites
