Go Schock Graphics 0 Posted January 7, 2016 Today I am cutting Vinyl lettering for a trailer. I am using Adobe illustrator to create my layout and then sending it to Sure Cuts Alot 3 Pro to cut on my Titan 2. The first file cut some of the text higher than the rest of the word. I decided to start all over with a fresh file and even arranged things a bit different. The same text is cutting out offset each time and then some are and some aren't. I created outlines in illustrator before sending to SCAL. Any idea why this might be happening? I have a customers vehicle here for install and need to figure out ASAP! Share this post Link to post Share on other sites
30-284 86 Posted January 7, 2016 If you are using scalp anyways then just lay it all out in scalp so there is no problem bringing it over from ill. Donn 1 Share this post Link to post Share on other sites
Primal Decals 621 Posted January 7, 2016 ive had the same problem before and wasnt able to figure it out m so i always design and then bring over to scalps and never script it over Share this post Link to post Share on other sites
security802 686 Posted January 7, 2016 Check your tracking of the vinyl, last time I had the issue it was tracking to one side towards the end of my run 1 Share this post Link to post Share on other sites
