Signs and Designs 17 Posted January 6, 2016 Can anyone give me tips on setting up my system- sc400 sawgrass printer, sublijet HD ink, texPrint-R paper using creative studio from sawgrass, and I have corel X-7 that I installed power driver. I did I print and it looks faded out coming out of the printer? Thanks Bob Share this post Link to post Share on other sites
arty-rc 645 Posted January 6, 2016 It will look faded and dull but when you sub and heat it, it should look much better. Share this post Link to post Share on other sites
Macon Innovations 227 Posted January 6, 2016 That's how it will look until applied to the substrate.... Share this post Link to post Share on other sites
Signs and Designs 17 Posted January 6, 2016 Thanks will let you know what happens Share this post Link to post Share on other sites
Macon Innovations 227 Posted January 7, 2016 And make sure you print on the brighter side of the paper Share this post Link to post Share on other sites
Signs and Designs 17 Posted January 7, 2016 Printing on what side of the paper is not a problem since there is writing on the back side. I did a test mug came out very light, is there somewhere where I can download a cheat sheet on time and temperatures. Share this post Link to post Share on other sites
Macon Innovations 227 Posted January 7, 2016 Not really.....I have good luck at 400 degrees and 60 seconds.....I've seen other people post all kinds of different times and close Temps...And you have to make sure you have enough pressure also Share this post Link to post Share on other sites
mfatty500 420 Posted January 7, 2016 Are you using a mug that is properly coated for sublimation? 1 Share this post Link to post Share on other sites
mr300s 1,272 Posted January 7, 2016 Yeah I do 400 degree for 6 minutes Share this post Link to post Share on other sites
Macon Innovations 227 Posted January 7, 2016 Mr300 , do you use a press or a wrap? I get great results at 1 minute.....Now you have me wondering.....Next time I make a mug I'm going to try for a longer time and see what happens Share this post Link to post Share on other sites
mr300s 1,272 Posted January 7, 2016 Both but everything i read is like 6 minutes both poly and ceramic I think Scott does 6 minutes also ... Share this post Link to post Share on other sites
Dakotagrafx 6,671 Posted January 7, 2016 15 min with the wrap 1 Share this post Link to post Share on other sites
Signs and Designs 17 Posted January 8, 2016 WOW 6 min. I went over the mug with another of the same image and did 400 degrees for 180 sec. and came out pretty good the paper was brown when I took it out, does that ay anything?, And I got my mugs and everything from sublimation 101 a start up package from the Atlantic city show. Share this post Link to post Share on other sites
jaybyrd 3,769 Posted January 8, 2016 WOW 6 min. I went over the mug with another of the same image and did 400 degrees for 180 sec. and came out pretty good the paper was brown when I took it out, does that ay anything?, And I got my mugs and everything from sublimation 101 a start up package from the Atlantic city show. That's close to where I'm set at with my press. If the paper is just starting to brown that is how I set mine up and it works fine that way. Share this post Link to post Share on other sites
mr300s 1,272 Posted January 8, 2016 Also if you have a way to check that the temp is what it says it is wont hurt either, some of the cheaper pressers can be off by a lot Share this post Link to post Share on other sites
GraphxNMore 278 Posted January 8, 2016 The mugs I get from Conde work best for me at 390° for 225 seconds. Share this post Link to post Share on other sites
MadHatterGraphix 1,258 Posted January 9, 2016 15 min with the wrap 12 min with the wrap here for ceramic and I believe the poly was that also. Share this post Link to post Share on other sites
