I have just purchased the US Cutter SC Plotter.  and Sure Cuts A Lot 3.  The cutter is not cutting the right direction.  I am cutting "Growing in Grace".  It is 15 inches in Hieight and 120 inches long.  It wants to cut it across the vinyl.  I have changed direction with my mat and it does not make a difference,,,, cuts the same either way.  Not sure what I am doing wrong
See if this helps:
Make sure the arrow on the outer edge of the mat board design is facing the correct way .The arrow points which way the material is going thru your cutter and as bustbays image as well. there shouldnt be any problems after that unless something else is wrong..  I use scalps 4 pro to cut and desing in Ai cs6
