Trillion
Is there a way to join the inner sections of fonts for reverse weeding?
Hey guys, so I have some text I'll be reverse weeding, and since it will be quite small I'm not happy about the tiny little inner pieces of letters such as B or R, O, D, g, etc, and the chance of them not coming away with the transfer paper.
Is there a way to join these to the outer section without having to manually edit each letter/number each time I do it?
Attached pic shows roughly what I'm trying to accomplish, and if there isn't a way to do this then are there any suitable fonts you would recommend? Thinking about it though, any font with the inner piece joined would simply come away with the rest of the letter when reverse weeding, so I don't think this would work either :(
Any ideas?
Thanks
post-95873-0-77657900-1451942053_thumb.p
you would need to un-compound, break apart curve, or whatever your program calls it. what program you are using would be helpful also.
