Charger_ff 46 Posted January 3, 2016 Does anyone know if US Cutter MH-721 will work on Windows 10? Share this post Link to post Share on other sites
slice&dice 2,450 Posted January 3, 2016 Why wouldn't it? Download and install SignBlazer ELEMENTS, and the FTDI standard CDM20828 driver, you should be good to go. http://support.uscutter.com/index.php?/Knowledgebase/Article/GetAttachment/190/24198 and http://www.ftdichip.com/Drivers/CDM/CDM20828_Setup.exe Share this post Link to post Share on other sites
mrd3036 0 Posted January 6, 2016 I'm trying to do the same thing. When I run the USCutter Drivers under the SignBlazer Elements folder, Select the USCutter MH Refine and Install, I get the "Cannot Complete the Device Drive Install Wizard, USCutter Printer (06/05/2011 6.10.00.00) Install failed" Any ideas? Share this post Link to post Share on other sites
79cutlas 0 Posted January 23, 2016 I'm trying to do the same thing.When I run the USCutter Drivers under the SignBlazer Elements folder, Select the USCutter MH Refine and Install, I get the "Cannot Complete the Device Drive Install Wizard, USCutter Printer (06/05/2011 6.10.00.00) Install failed" Any ideas? I just installed my MH721 tonight and it was was a bear to get past the Windows 10 driver signature verification. I found a nice how to on going to settings and bypassing it with a google search. Share this post Link to post Share on other sites
slice&dice 2,450 Posted January 23, 2016 I'm trying to do the same thing.When I run the USCutter Drivers under the SignBlazer Elements folder, Select the USCutter MH Refine and Install, I get the "Cannot Complete the Device Drive Install Wizard, USCutter Printer (06/05/2011 6.10.00.00) Install failed" Any ideas? Yes, I have the solution. Don't even try to install USCUTTER machine-specific drivers. Just go into the SBE cutter setup and choose the RedSail brand (the 721 is RS800c) That will be sufficient to run your unit. Share this post Link to post Share on other sites
DecalAvenue 7 Posted January 25, 2016 I have the same cutter and I use it on win 10 without problems. now, what I have is a problem with the blade holder i think. Seen to me that the holder is not straight, any idea? or the holder suppose to be like that? thanks. Share this post Link to post Share on other sites
Jimbo 0 Posted June 24, 2016 I have downloaded the more current version of SignBlazer Elements on my Windows 10 PC, and I'm still unable to cut anything with SignBlazer. I also have Sure Cuts Alot 3, and it operates the cutter just fine. "Can not open the output device. Error initializing cutter" Share this post Link to post Share on other sites
arty-rc 719 Posted June 24, 2016 I have downloaded the more current version of SignBlazer Elements on my Windows 10 PC, and I'm still unable to cut anything with SignBlazer. I also have Sure Cuts Alot 3, and it operates the cutter just fine. "Can not open the output device. Error initializing cutter" Check your output device settings in the cut screen setup. Share this post Link to post Share on other sites
Jimbo 0 Posted June 24, 2016 Check your output device settings in the cut screen setup. What should it be? It's currently "Blazer Com1". Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted June 24, 2016 Signblazer output Com number, should match the com number in your computer device manager...that you are using. Go to your computer device manager and see which com port number is being used. They must match. to make your cutter work. Share this post Link to post Share on other sites
arty-rc 719 Posted June 24, 2016 What you can do is try them all until you find the one that works. Make sure you have your cutter hooked up to your computer so it will see it. Share this post Link to post Share on other sites
Primal Decals 621 Posted June 24, 2016 I have the same cutter and I use it on win 10 without problems. now, what I have is a problem with the blade holder i think. Seen to me that the holder is not straight, any idea? or the holder suppose to be like that? thanks. That does not look right to me...lol.. Share this post Link to post Share on other sites
Jimbo 0 Posted June 26, 2016 What you can do is try them all until you find the one that works. Make sure you have your cutter hooked up to your computer so it will see it. I know which one works, because that port works with Sure Cuts A Lot 3. Something in the program itself. US Cutter Support tells me that Sign Blazer Elements is not compatible with Windows 8 or 10. But, if some of you are using it on Windows 10, that makes me wonder what I'm missing. Share this post Link to post Share on other sites
Charger_ff 46 Posted July 9, 2016 I just upgraded my computer to windows 10. I didn't have to do any changes to the preference of the cutter and anything else. Sign blazer and Inkscape worked perfect 1 Share this post Link to post Share on other sites
Bertie 5 Posted July 17, 2016 I know this is quite an old post but my settings for my MH721 remained the same when I upgraded to Win 10 (from Win 7) made no difference and everything worked ok after the upgrade. Here's my settings; Cutter: Creation PCut CT630 Output Device: Blazer.COM4 . USB Serial Port Share this post Link to post Share on other sites
Charger_ff 46 Posted July 23, 2016 Same here cutter working fine Share this post Link to post Share on other sites
RoundalCutter 0 Posted July 30, 2017 Just to revisit an old thread, I have just got a second laptop to dedicate to graphics work and downloaded Signblazer using the link provided by slice&dice (thanks). With no MH721 driver I have tried the Redsail 800c and the Creation PT630 drivers as discussed above - but without success; in both instances, Signblazer traces the proposed cutting path but then doesn't seem to send to cutter. Anyone have any thoughts? I still have Signblazer on the original laptop (which works) - is there anyway to extract the driver and transfer to new laptop? Any assistance would be gratefully received! Garry Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted July 30, 2017 31 minutes ago, RoundalCutter said: Just to revisit an old thread, I have just got a second laptop to dedicate to graphics work and downloaded Signblazer using the link provided by slice&dice (thanks). With no MH721 driver I have tried the Redsail 800c and the Creation PT630 drivers as discussed above - but without success; in both instances, Signblazer traces the proposed cutting path but then doesn't seem to send to cutter. Anyone have any thoughts? I still have Signblazer on the original laptop (which works) - is there anyway to extract the driver and transfer to new laptop? Any assistance would be gratefully received! Garry Support page https://support.uscutter.com/support/solutions/folders/14000106611 Share this post Link to post Share on other sites
slice&dice 2,450 Posted July 30, 2017 FTDI chipset driver installer http://www.uscuttersupport.com/downloads/Drivers/cdm20828_setup_windows.exe That old, unsupported SignBlazer program is not listed anywhere on the USCutter support page anymore, so it's impossible to locate unless you have this 'secret' URL, so I do feel the need to repeat here the download link for the hybrid version (in the HELP/About menu it shows release v.7.0.0) SBE v7 (unlocked) http://www.uscuttersupport.com/downloads/Software/SignBlazer/signblazer_setup.exe Garry, glad you got SignBlazer installed OK, and it appears you gotta check your (Win10 Device manager) com settings and then make sure you've got the right baud rate in SB Cutter Setup. I think you're supposed to drop it from 9600 to 4800 for the MH721-MK11 Share this post Link to post Share on other sites
RoundalCutter 0 Posted August 2, 2017 Quote Thank you for both responses, I'll go through the set up again this week and see how far I get! SignBlazer has proved very useful (and quite capable) so I don't want to have to give up on it yet! Garry Share this post Link to post Share on other sites
RoundalCutter 0 Posted January 10, 2018 Ok, family circumstances have conspired to stop me getting to grips with my MH721/Win 10 issue since my last post. I have just been through the process of downloading and trying to update the driver but still have a real issue. In Device Manager, when plugged in to USB and switched on, plotter comes up as Ports (COM & LPT) USB-SERIAL CH340 (COM4) When I try to update using the driver from support page, Win 10 says most suitable driver already loaded After updating driver it does not move to the Printers Group in Device Manager Moving to SignBlazer, and go to cutter set up, I can see blazer.COM3: - USB-SERIAL CH340 in Output Device but MH721 doesn't show I'm list of cutters. Please, does any one know where I am going wrong? Garry Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted January 10, 2018 your plotter will not show as a printer as it is not a printer - as far as it showing in the list of cutters depending on the the version of signblazer it could show under uscutter sub menu or under refine that makes the plotter - I wonder if the UK version of the mh721 uses a different mainboard than the us version Share this post Link to post Share on other sites
RoundalCutter 0 Posted January 10, 2018 2 minutes ago, Dakotagrafx said: your plotter will not show as a printer as it is not a printer - as far as it showing in the list of cutters depending on the the version of signblazer it could show under uscutter sub menu or under refine that makes the plotter - I wonder if the UK version of the mh721 uses a different mainboard than the us version Thanks for the response. Refine doesn't show in list. Should I try find another version of signblazer? is their other software I could try? Share this post Link to post Share on other sites
darcshadow 1,626 Posted January 10, 2018 I think it is redsail. Share this post Link to post Share on other sites
