Keystone Kustom Decals 11 Posted December 25, 2015 I know every cutter is different but what are the common settings for cutting Siser Easyweed Stretch on an MH series cutter?? Dont want to waste a bunch of HTV trying to figure it out... Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted December 25, 2015 I use the same setting as I use for regular vinyl 2 Share this post Link to post Share on other sites
mb20music 760 Posted December 25, 2015 I use the same setting as I use for regular vinyl Yes you should be able to use the same settings, if your blade is a little dull you may just need to increase the blade depth a hair... Share this post Link to post Share on other sites
Wildgoose 4,200 Posted December 26, 2015 Yep same as regular vinyl. Stretch is slightly more resilient and will sometimes give you trouble with an old blade. Share this post Link to post Share on other sites
