busterbay
How do I split a vector in two CD 6x ?
How do I split a vector in two using 6x ?
I grabbed a vector at random ( drawn in black ) , I drew a curve ( in red ) and I want to split the vector in two using the curved line.
See attached files.
Thanks,
BB
post-64078-0-45190200-1450271689_thumb.j
sample.zip
I think "Back minus Front" should work on this.
You have to convert the line to an object  (Edit: add some width to line first)
Select both
Arrange>Shaping>Back minus Front
Then break object apart.
Sue2
You have to convert the line to an object first.
Select both
Sue2
Thanks, that didn't seem to work... so I tried front -back It left the line in segments. I wonder if i a setting incorrect.
post-64078-0-46390100-1450272849_thumb.j
Check that - I forgot to add a width to the line. Worked like a charm once I did that.
post-64078-0-13250600-1450273809_thumb.j
Plus, there are several pieces to the flames graphic...
sometimes Corel can be fussy doing all pieces at one time....
other times not!
:huh:
Glad it worked for you!
Sue2
other times not!
:huh:
Sue2
I noticed that about Coreldraw. This isn't the graphic that I wanted to split but I figured if I could get it to work on this one others should be a breeze. It's funny how sometimes the answer can be right in front of your nose.
