mrfibble
curving text??
lets say i have XXXXXXXXXXX and i type that into inkscape how do i then make it arc/curve  etc into an arched shape ?
 cheers
david c
There should be some help topics right in the Help menu within Inkscape. Can't remember if they are links to youtube or not. Basically you either draw a line and then type text on it or you write out your text then manipulate it with one of the tools in the program. If you can't do youtube then you better look and find some downloads tons study. There will be lots of info available. here is a start. If you can't find the search engine called Google you probably will never figure this out so give up now.
https://inkscape.org/en/learn/tutorials/
cant do youtube vids   :(
David
That wasn't a youtube video above.  It was a tutorial,  with many more tutorials,  Tips and Tools and Videos. for Inkscape.
You don't even have to type in Google,  just use the mic and speak...It's just too easy...
Basically, draw the curve or arched path with the Bezier pen.
Type out the text.
Select the text and shift select the curve.
Then Menu>Text>Put on Path.
Here are links to a few good primers and Tutorials for Inkscape;
http://www.angelfire...cape/index.html
http://tavmjong.free.fr/INKSCAPE/
http://en.flossmanuals.net/Inkscape/
http://tavmjong.free...ml/Anatomy.html
http://speckyboy.com...using-inkscape/
http://www.metacafe....about/inkscape/
http://inkscapetutor...utorial-list-2/
