Signman71 0 Posted November 28, 2015 Graphtec says I have a bad (Y) motor on my F7000-75 that they no longer can supply. I am trying to locate a part for replacement, thanks Any advice would be greatly appreciated. Share this post Link to post Share on other sites
mb20music 760 Posted November 28, 2015 If you are having issues with the Y-Axis take a look at the gear that the drive belt is attached to. It has a wider bottom and a thinner top and sometimes the two pieces will separate causing errors and it has a hard time finding the pinch rollers. 1 Share this post Link to post Share on other sites
bikemike 711 Posted November 28, 2015 When you use the direction buttons, can you hear the motor running with no movement? Share this post Link to post Share on other sites
