H2Ohydrographics 25 Posted November 10, 2015 I feel like I should know how to do this, but ughhhhhh, cant figure it out! How do I or whats best tool to use when I wanna do something like in pic. I mean when I cut my 2 colors and get ready to press em, I want the courageous to lay or fit inside the ampersand, not on top. Does that make sense? Thank you so very much, Anna (I use Corel Draw) Dont need the strong and courageous just wanna learn to cut words out of whatever, ex:ampersand and layer inside of each other not on top of each. Share this post Link to post Share on other sites
mark-s 1,126 Posted November 10, 2015 Right out the gate I say custom but I`ll check mark-s 1 Share this post Link to post Share on other sites
mb20music 760 Posted November 10, 2015 Definitely custom, the e's. g's. r's and o's are not the same... 1 Share this post Link to post Share on other sites
Sue2 920 Posted November 10, 2015 To make one like that.... you need to take the overlapping pieces out of the ampersand... In Corel: Select both, Use Arrange/Shaping/Back Minus Front. Sue2 2 Share this post Link to post Share on other sites
H2Ohydrographics 25 Posted November 10, 2015 Sue, thanks, but how do I leave it in and cut it so my words are cut out of it and I can lay layer inside of it. Does that make sense? Share this post Link to post Share on other sites
KYSIGN 233 Posted November 10, 2015 Copy the courageous with control+c and do as sue said then press control+v to paste the text back. 2 Share this post Link to post Share on other sites
H2Ohydrographics 25 Posted November 10, 2015 Thanks so much, im heading out to shop now. Share this post Link to post Share on other sites
mark-s 1,126 Posted November 10, 2015 No match mark-s Share this post Link to post Share on other sites
Wildgoose 4,200 Posted November 10, 2015 Just an FYI. When I do this I typically use a slightly larger version of the original so there is a little room around the inside lettering. In AI I do a path offset on the courageous then use that offset to punch out the ampersand. Not sure the procedure entailed with Corel to do the same thing. 1 Share this post Link to post Share on other sites
knucklehead 530 Posted November 10, 2015 In Corel, the trim function does too. Group, then trim. Like Goose said, put an outline on courageous, then trim. Share this post Link to post Share on other sites
louis clarke ii 202 Posted November 10, 2015 Send the file and I can do it real quick. The wording over the ampersand you need to do an outside contour. Then with the slightly larger contour, simplify it will create a void around the ampersand. Share this post Link to post Share on other sites
djque 246 Posted November 11, 2015 also the words on that shirt isnt cut out. there layered. Share this post Link to post Share on other sites
xpaperman 719 Posted November 11, 2015 easy in sign blazer.... use weld/punch through! Share this post Link to post Share on other sites
MadHatterGraphix 1,258 Posted November 11, 2015 or lay the one piece on top of the other and use either simplify or trim. Share this post Link to post Share on other sites
