Signs and Designs
MH-1350
RedSail RS1360C should be listed. That is the manufacturer's OEM spec driver -- RedSail.
Edited by slice&dice
RedSail RS1360C should be listed. That is the manufacturer -- RedSail.
so redsail started making the refine cutters?  when did that change happen?
I should have said "OEM" drivers.
No biggie, the result is the same, that cutter will fire up like a 767jetliner (and probably sound like one too, as the CHinese manufacturer -- whomever it was --- cut a few corners to get that cool machine into our hands for so little $$$)
Thank you, will try tonight. I brought this machine for a job that I needed a piece of vinyl 48 x 55
no seams. that job paid for the cutter. now it gets used maybe a dozen times a year. But nice to have when needed.
LOL you are just too much
Thank you Slice&Dice it worked perfectly and fired up like a 747 jetliner.  Also got the MH-1351 to work perfectly with vinyl master pro ver. 4 with their supplied driver  Thanks again
It's all good ---  you're welcome.
I am currently morphing away from SignBlazer into VinylMaster CUT and while I see the advantages in VM, the old ways of the cartoony-GUI of SBE still hold tremendous attraction for me.
