Charger_ff 46 Posted September 30, 2015 How can I get an image that is in grayscale to vectorize in sign blazer. When I click on vectorize it say that it can't because the image is not monochrome Share this post Link to post Share on other sites
slice&dice 2,450 Posted September 30, 2015 Easy to do -- With the image selected, choose MODE from the Image menu, and the first submenu will offer Monochrome as an option. You can then adjust the density/intensity using the sliding scale which appears automatically (50% is the default). From there, you're good to go. Share this post Link to post Share on other sites
Charger_ff 46 Posted September 30, 2015 Just tried it. Not what I was thinking. Was trying to do silhouettes Like they show in the us cutter email. Link below https://vimeo.com/140344391?utm_source=USCutter+List&utm_campaign=e96c6fead3-USCutter_Weekly_Specials_9_29_15_9_28_2015&utm_medium=email&utm_term=0_78aca4451f-e96c6fead3-71110609&mc_cid=e96c6fead3&mc_eid=df400315c2 Share this post Link to post Share on other sites
slice&dice 2,450 Posted September 30, 2015 That has nothing to do with SignBlazer. Share this post Link to post Share on other sites
Charger_ff 46 Posted October 1, 2015 i have only SB. And would like to do what they are showing in the video. Just need help figuring out how to do it Share this post Link to post Share on other sites
darcshadow 1,625 Posted October 1, 2015 Never knew power point could remove backgrounds so well. That's pretty cool. SB can vector stuff but I've never had any luck getting it to work. I'd suggest downloading Inkscape (free) and play around with it. There are lots of tutorials on vectoring images in Inkscape, look through some of those and you will be able to do the above process with Inkscape. Share this post Link to post Share on other sites
