TrickyTricky 0 Posted September 29, 2015 Hi I am having A problem when I upload dxf (R11) file to Moshi Draw 2015. I am using TurboCAD to make the dxf file. What is going on, is I have multiple parts on the dxf file. If I isolate one part and run it on Moshi Draw, it works great. But if I try to run the 4 parts, The laser cutter head go to the home position and then to the origin (fast and forever). Here is the dxf file. (4 Parts) Now I can Cut All the parts out on the file (Parts That Will Cut Out.pdf) Why can one dxf file let me cut out all the parts at one time and the other file stops the laser Cutter. Parts That Will Cut Out .pdf 4 Parts.pdf Share this post Link to post Share on other sites
