mweintraub
Cutting paper on the MH721 MK2
It's possible. I used my old Mh721 to make a few small foldable boxes from card stock. I used a large cutting mat designed for cricut machines.
Thanks. If the poster board idea doesn't work, I'll order a cutting mat.
I use either clear app tape or the carrier backing off Siser HTV vinyl (which is sticky) and cut crafty letters and such for my kids from time to time. I don't have an MH cutter but a cutter is a cutter. You just need something with a little tack that will act as a carrier sheet. I have one of the Cricut mats too but they are pretty stiff and don't always act like you want and are too sticky sometimes.
I want to try something for test cuts.  Vinyl is expensive.
Card stock is a good idea.
Thanks.
Use a pen attachment for fooling around in the early learning stage. Most cutters come with one. Paper is actually hard on your blade.
