brunelloinc
Blade holder SLAMS down on initial cut
Hi All,
I have a new CE6000-40 and I'm new to cutting.
I'm not sure if this is normal or not, but the bladeholder seems to slam down pretty hard on the vinyl when it starts a new cut.
I've attached a video showing the behavior. Is this how it's supposed to work or is that a little aggressive?
I've pasted all of my software settings below. These settings are controlled in Cutting Master 3 and synced back to the cutter over USB.
On the cutter itself, I have the setting for "Initial Down Force" set to 1 (the lowest setting). I don't see an equivalent setting on the computer software side.
Details:
Here's are the details of my equipment and settings:
Graphtec CE6000-40 Cutter
Blade: Graphtec CB09U-K60 (60º, 0.9mm)
Condition:
Offset: 0
Speed: 1 cm/s
Acceleration: 0
Cut Force: 10
Passes: 1
Tangential Mode: Off
Tool Setting:
Step Pass: 0
Offset Force: 2
Offset Angle: 0
Initial Blade Position: 2mm Below
When Tool is Up:
Speed: Auto
Advanced:
Move Step: 0.1mm
Step Size: 0.010mm
force.mov
Is it actually cutting when you send a job? When I got mine I didn't have the blade holder snapped all the way in so it wasn't cutting but did make a loud slamming noise until I got it properly seated.
Yeah, it's cutting just fine I was just worried that it was going down a little too hard and thought maybe I didn't have something set correctly. After you got the blade holder seated correctly, does it still slam?
What ever happened on the circle problem?.. You never updated on it.
