kainth.c.s 53 Posted September 23, 2015 Hello everyone I am from australia and a newbie in vinyl cutting business. I got an order to cut AVERY 900 Supercast series vinyl for an ACM (Aluminium Composite Metal) board sign which will be put externally. I own Creation PCUT CT0630 (Black and Red) cutter and use Flexi 10 for designing and programming. The data sheet of this vinyl is attached as well. Any special serttings/precautions need to be taken while doing it????. The setting I have been using are: Press 118 Cut speed: 50 45 deg blade Any imputs from anyone would be welcomed Regards C.S.Kainth av9.pdf Share this post Link to post Share on other sites
MadHatterGraphix 1,258 Posted September 23, 2015 Contact avery through email ask them the blade type and pressure is different on all machines. Do some test cuts however I would use a 60 degree blade. 1 Share this post Link to post Share on other sites
pshawny 410 Posted September 23, 2015 With any new material you'll have to sacrifice a little bit of material to the vinyl gods. Cut some small text until you get it to weed easily and just barely score the backing paper. 1 Share this post Link to post Share on other sites
darcshadow 1,626 Posted September 23, 2015 I have no experience with this vinyl but looking at the spec sheet it just looks like standard cast vinyl. It's 50 microns thick which is about 2mils, which is what the Oracal 751 vinyl is. Don't believe you'd need to do anything special other than slight adjustment to blade depth and/or pressure just like you should do any time you change vinyl, even different colors of the same type of vinyl can need slight adjustments to cut settings. 1 Share this post Link to post Share on other sites
kainth.c.s 53 Posted September 23, 2015 Hello Pals Thanks for your advice and valueable inputs. I did give it a try with the normal settings . I did have some problems in weeding, particularly at the corners but overall it went fine. Morever, is there any way by which we can manually select the sequence of the shapes. For instance if I am to cut the word SINGH, it normally makes half of letter H first, then comes back does bottom half of S then so on , i.e. in a random way.If I export the drawing to dxf in autocad and change the lines to Polyline (PEDIT --Join) and import in flexisign afterwards, it cuts the full letter but not in the sequence, i.e. it cuts H then N but not in a sequence. I also mailed SA international( Flexi Sign software) and also made a query to the importers of the vinyl cutter but haven't got any reply from them. Please share if anyone came accross the way to do it. Regards C.S.Kainth Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted September 23, 2015 No you cannot select the sequence, of cutting.. You can only select an area,,,in Optimize cutting order. Like 5 inches of area, then advance 5 inches, clear to the end. I cut large decals, the cutter may advance the vinyl 5 ft before it starts cutting, but it will come back and finish the full design.. It starts cutting where the start of the design was created at. Share this post Link to post Share on other sites
kainth.c.s 53 Posted September 24, 2015 Thanks Mz SKEETER Regards C.S.Kainth Share this post Link to post Share on other sites
Wildgoose 4,200 Posted September 25, 2015 Write a string of text and do your conversion you are speaking of and then post it. I would like to see it and try something. Share this post Link to post Share on other sites
