RickS 39 Posted September 10, 2015 How can I get rounded corners on a square in flexi, I have tried the outline feature and it doesn't get what I want. I just need to put a slight radius on the corners. It probably is stupid easy but I must be stupid, help. Share this post Link to post Share on other sites
mfatty500 454 Posted September 10, 2015 Draw your rectangle, or square, design central will open & (likely change) click on the little rectangle icon, then you select rounded, clipped, inverted, or regular. Share this post Link to post Share on other sites
RickS 39 Posted September 10, 2015 Thanks, I will give that a try when I get home tonite. Well a little update, worked just like you described, thanks for the flexi lesson. I had never used that function, now to remember it for next time. so much to learn. Share this post Link to post Share on other sites
