ssimsa 0 Posted August 4, 2015 So I've owned this cutter for over a year and a half now.. Have had a few issues but nothing I couldn't fix.. Recently the cutter hasn't been able to cut straight lines very crisp as is was a few days ago. Tried switching to 60 degree blade a few days ago and that may have been the issue, just switched back to the 45 degree and still having the issue. One source I found about these symptoms says to adjust the blade offset but I don't see that setting on the SC's control panel. Here are a few sample shots of what's going on.. Here's a shot from the beginning of the cut then towards the end of the roll it gets even sloppier: It really shows in the Es and the Hs.. Thoughts? Thank you for your time! Share this post Link to post Share on other sites
Quitetitan4 90 Posted August 4, 2015 Is this the only file its doing this on? Share this post Link to post Share on other sites
