delboy2028
advnaced after cut
My CR360 does not advance after cutting with the signcut program.
with flexi it advances
with signcut when it finishes the weeding boarder it stops with the arm down and i have to press reset for the arm to lift and the vinyl to be released.
You should be able to go to settings in sign cut and there should be a option to do that in there even though I dont have sign cut ...
post-2057-0-67503200-1437930347_thumb.jp
There is possibly some driver issue if it is stopping with the blade down. SignCut has the distinct advantage of true live tech support. They are good and they are fast so give them a call and they will get you figured out in very short order. mr300s showed the right menu to look for the settings although I think that look may vary a little depending on the actual cutter you are using. Some of the pages and options were different from my old P-Cut to the Summa. Great cutting program and one that is both Mac and PC compatible.
