top53 53 Posted July 21, 2015 My advance vinyl position buttons and orgin button are not working. It does load the vinyl. Does this sound like a circuit board problem? I have not cut in awhile and always unplug the machine when I am finished using it. Share this post Link to post Share on other sites
jaybyrd 3,770 Posted July 21, 2015 Does it still cut? If so it may be the control panel itself but that's just a guess. Share this post Link to post Share on other sites
top53 53 Posted July 21, 2015 Thanks Jaybird, I found the problem. Seams like I have had a vistor he cut thru 4 of the lines. Do you know where I can get this cable it goes from the front pad to the circuit board? Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted July 21, 2015 what is the full Sumitomo number on that? How many pins? Share this post Link to post Share on other sites
jaybyrd 3,770 Posted July 21, 2015 http://www.ebay.com/itm/221239217723?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT Trust me this will fix ya but it took around a week to come in. My cable was broke when I changed my motherboard and that fixed it. Share this post Link to post Share on other sites
jaybyrd 3,770 Posted July 21, 2015 just making sure yours is the same as the ce5000 series cutter correct? Share this post Link to post Share on other sites
top53 53 Posted July 21, 2015 Sorry had to go out on a job. Full # is AWM 20661 105C 60V VW-1 -F- My eyesight is not good enough to count those little wires I may have to find a loop if I need that infor. Yes it is ce5000. Thanks for the help. Share this post Link to post Share on other sites
jaybyrd 3,770 Posted July 21, 2015 Yeah I just bought the one I linked to for mine and it worked fine. Share this post Link to post Share on other sites
top53 53 Posted July 21, 2015 Jaybird, thanks I've got it ordered. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted July 21, 2015 Need a spare? Here is a used one in Florida Tested to work SUMITOMO-G AWM 20661 105C 60V VW-1, 10.5" RIBBON CABLE, 30 PIN Only 1 availableDetailsShipping: US-Mainland: free (more destinations) Condition: Used Share this post Link to post Share on other sites
top53 53 Posted July 21, 2015 Mz Skeeter the ad title shows SUMITOMO-G AWM 20661 the ad description says SUMITOMO-G AWM 20861 105C. Do you think they are the same? I would like to find one in the States, I have not pulled the trigger on the one (Jaybrid) told me about yet, because it is in Bangkok, Thailand. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted July 21, 2015 contact them, they have a phone number. and email. http://www.komputersrepairs.com/ Share this post Link to post Share on other sites
top53 53 Posted July 21, 2015 Good idea, unfortunately it was sold on Ebay and he had not updated his Ecater account. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted July 21, 2015 Good idea, unfortunately it was sold on Ebay and he had not updated his Ecater account. So did you ask if they were the same? Or if that part number would work? Share this post Link to post Share on other sites
jaybyrd 3,770 Posted July 21, 2015 Take the description of what I linked to as far as pins and the rest and you may be able to find one at a local computer shop. I don't have the time to run around and it wasn't my main cutter so I chose to order it. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted July 21, 2015 Sorry had to go out on a job. Full # is AWM 20661 105C 60V VW-1 -F- My eyesight is not good enough to count those little wires I may have to find a loop if I need that infor. Yes it is ce5000. Thanks for the help. So is this it? What are the pins amount. ? http://www.ebay.com/itm/Sumitomo-C-AWM-20661-105C-60V-VW-1-F-Used-12-pin-Ribbon-Connector-Good-/181615669059 Share this post Link to post Share on other sites
jaybyrd 3,770 Posted July 21, 2015 needs to be 30 pin. From what I learned the pitch determines the number of pins in a given size and the pitch he'll need is .5mm width is 15.5mm and length around 300mm. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted July 21, 2015 needs to be 30 pin. From what I learned the pitch determines the number of pins in a given size and the pitch he'll need is .5mm width is 15.5mm and length around 300mm. So is that what the Y means after Sumitomo on his picture? I see others Sumitomo C and G Share this post Link to post Share on other sites
jaybyrd 3,770 Posted July 21, 2015 I really don't know if it is the pitch or wire gauge but it may be. when I started to look for a replacement the 3 things that kept popping up were width, pitch and length. That's all they ever wanted to know. I know the number with the c after is the temperature and the one with the v after it is thte rated voltage but don't know any of the other letters. Pitch : 0.50 mm Pin : 30 (wide : 15.5 mm) Length :300 mm (30 cm) Share this post Link to post Share on other sites
jaybyrd 3,770 Posted July 21, 2015 I still need to order the one for my carriage so I can use the polling features because 2 of the wire were damaged in that cable too on mine. Share this post Link to post Share on other sites
jaybyrd 3,770 Posted July 21, 2015 http://www.ebay.com/itm/5-Flexible-Flat-Cable-FFC-30Pin-0-5mm-Pitch-300mm-Forward-Direction-Ribbon-Cable-/151666670498?pt=LH_DefaultDomain_0&hash=item235009bba2 I think this is you and it's in NY. Might want to contact the seller with the specs I listed above to confirm plus you'll have a couple spares to sell. 2 Share this post Link to post Share on other sites
top53 53 Posted July 21, 2015 I had to go out on another job just got back in. MZ Skeeter I did not ask, it was hard for me to understand him he had a strong India dialect. Share this post Link to post Share on other sites
top53 53 Posted July 21, 2015 Jaybird, I ordered the last link you sent looks like I will have back up. if anyone needs one let me know. Share this post Link to post Share on other sites
jaybyrd 3,770 Posted July 21, 2015 If for some reason they are wrong let me know and I'll help you out with mine and reorder one for mine since it's just my backup. Share this post Link to post Share on other sites
top53 53 Posted July 21, 2015 Thanks I appreciate it but I have a back up cutter, I just like this little Graphtec. Share this post Link to post Share on other sites
