vegasrett 0 Posted July 1, 2015 I don't know where to begin. I work for a glass engraver and we have started screen printing as well. this works well for one or two colors but multi color has proven cumbersome. we are looking for a simple way to do full color photos, and gradient shading on restaurant quality glassware. is anyone here doing such a thing? and what is the smart way to do it? does sublimation stick to glass or is it just for ceramics? can we prep our own blanks in house? will the prep coat fog or off-color the glass? can sublimation be oven/kiln heated, or would we have to clamshell each glass one at a time? is there a digital print and cut system that offers a permanent (500 dishwasher cycles) image on glass? this would just be too easy, right? is there a digital print company that makes a printer we can run our glass screen printing inks through (as we know they are permanent) to produce water-slide transfers? how permanent are water slide transfers printed with "standard" (and what are the standard) inks? any help with any of these questions would be appreciated. thanks rett Share this post Link to post Share on other sites
OWJones 1,981 Posted July 2, 2015 Sublimation only sticks to polyester, so any surface with an appropriate polyester coating will take sublimation, assuming it can withstand the 400° F sublimation temps. It has to be held against the surface with a great deal of pressure to prevent outgassing of the dye, so you would need a heat wrap for every glass you try and do at once - 10 wraps = 10 glasses at a time. If you're looking for something that will actually stand up to restaurant use (meaning multiple washings on a daily basis and being handled by hundreds of random strangers), then I don't think sublimation is the answer you're looking for, as it isn't meant to hold up to those kinds of use. I don't know of any water slide transfers that will stand up to that kind of use and abuse - not saying they don't exist, it's just not something I've ever gone looking for... Share this post Link to post Share on other sites
pshawny 410 Posted July 2, 2015 Here are some interesting videos that I found with a quick YouTube search. It looks like waterslide transfers can be used. 1 Share this post Link to post Share on other sites
vegasrett 0 Posted July 2, 2015 Thanks to you both for a timely reply. at this point water slide is looking more promising than sublimation, but nothing is being ruled out. the sublimation process seems simple and the tech already exists. and the glass can be treated at a low (400 degree) temperature allowing us to run small wrapped batches through an oven for just a few minutes. they could then be pulled out, replaced with another batch, and allowed to dry at room temperature. no one can tell me how permanent it is, or if the polyester coating will stick well to glass, or off color clear glass. I know there are some differences between glass types, but is anyone sublimating flat glass with any permanency? the water slides seem like a more difficult method to cure (at 1600 degrees) and have to cool slowly to prevent "glass sag". this would slow the process to a crawl allowing 2 or 3 batches to cure a day. if our screen printing inks can be used however, we know for sure that they will take 500 washes. this may mean modifying an inkjet printer to run a very strange ink. potential for clogging and smearing here seems like a nightmare. any more thoughts would be greatly appreciated. rett Share this post Link to post Share on other sites
nivr 0 Posted July 9, 2015 Digital ceramic printing in glass: My name is Niv. Head of architect division in Dip-Tech. Attached is a link to our website. I think you can find what you need there. If you need more help or consultant, please contact me by email: nivr@dip-tech.com www.dip-tech.com Share this post Link to post Share on other sites
