Cosmic1 1 Posted July 1, 2015 Hi. Recently bought a graphtec ce 6000 60 plotter. I have been running my business for 8 years with a pcut. The new plotter is great, however im cant seem to cut any wider than 58.3cm. i have read through the forums, and i have turned off the pinch roller sensors and the media sensor. But 58.3cm is all it will give me no matter where i place the rollers or setup the vinyl. I read somewhere that the max cutting width should be 60.3cm., Cant work out what i am doing wrong or is this actually the maximum?? Share this post Link to post Share on other sites
DCMoney 91 Posted July 1, 2015 I recently had to look up how to do the same thing since I wanted to cut outside the pushrollers max width of ~22.9". Its in the manual under Setting Cutting Width (EXPAND) Page 4-4 https://www.specialty-graphics.com/media/pdf/CE6000-Users-Manual.pdf On the cutter itself it's under "Area", then "Expand", then you can adjust the "Set Expand Limit" to +- 10mm at +10mm it should give you the max cut available. 1 Share this post Link to post Share on other sites
Cosmic1 1 Posted July 7, 2015 DC money you are a life saver cant thank you enough. . Its a great cutter, definatly a step up from my pcut. 1 Share this post Link to post Share on other sites
