hulkhauler1 0 Posted June 28, 2015 I use inkscape and the text is perfect but when I open it in signcut there are no straight lines as in the letters l (ell)& I(eye) and the bar in a phone number 253-588-1600. It does this no mater what font I use. Any help would be appreciated. Thanks Share this post Link to post Share on other sites
hulkhauler1 0 Posted June 28, 2015 I forgot to add the fact that it wont cut them either. An example would be G FT (GIFT) or T SH RTS (T-SHIRTS) Share this post Link to post Share on other sites
slice&dice 2,450 Posted June 28, 2015 Download and install SignBlazer and try to cut, let us know what happened. http://support.uscutter.com/index.php?/Knowledgebase/Article/GetAttachment/190/24198 Share this post Link to post Share on other sites
KYSIGN 233 Posted June 28, 2015 Have you tried converting the text to shapes? Share this post Link to post Share on other sites
signyouup 178 Posted June 28, 2015 +1 on what KYSIGN said. In Inkscape it's call covert to path. Share this post Link to post Share on other sites
Wildgoose 4,200 Posted June 28, 2015 SignCut has as good of live tech supports as exists in the universe, and I do not exaggerate. Give them a call and they will get you figured out. The only thing I have ever seen similar was once in a while it would leave off one side of the weeding frame but that was an older version and running on an internet key. Since the new download I have not had any issues and I run a dongle now too. I doubt either of those have anything to do with what you are experiencing. If I had to guess it is something to do with the file conversion from Inkscape. Possibly SignCut is loosing something as it transitions things over. Have you tried sending it with fills vs stoked lines to see if it makes a difference? I work in AI and SignCut likes AI version 8 the best and the few times I had any issues I was using the plug-in from CS5 and letting the plug-in convert the file to the preferred version 8. Once I started saving my cut files as version 8 then no more issues. I originally thought this was a bit odd but then when I got my Summa the software that came with it required files in AI version 3 so at that point I realized there are variables within the newer versions that cutting utilities don't need and must have trouble interpreting such as multiple art boards etc... Share this post Link to post Share on other sites
