dee10w 29 Posted June 20, 2015 hiya after getting rid of the Mimaki as i could not afford to fix it i now have a HP5500ps running bulk ink, Does anyone on here still run one as im having a few probs with media/ink compatabilities, if some one could shed some light on info that would be ace, cheers dee Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted June 21, 2015 As I understand that model it uses water based dye ink with uv inhibitors to make it last a little longer so you would still need vinyl that is coated for aqueous inks and laminate to get any life out of it outdoors - it is not going to be like the solvent mimaki that actually bit into the vinyl this ink will only adhere to that coating sprayed on top Share this post Link to post Share on other sites
