wolfecc 0 Posted May 12, 2015 I am having no luck cutting the holograph from siser. I have wasted about 5 feet. I have got the blade the right height and when I put in the machine to cut it wont cut it all the way through, or if it does it rips as I try to weed it. Plus cant see to weed it. Any suggestions? What blade do you use? I have titan 2 cutter. Share this post Link to post Share on other sites
dcbevins 340 Posted May 12, 2015 I haven't tried the holographic. I imagine it is about the same for this discussion as the glitter. A 60 degree blade seems to work better with correct offset. More force is needed, 180-200 grams seems to be my range. Again, assuming it is like the glitter. I mention this, because I did it once, make sure its not loaded upside down. I have found that on HTV if you warm your press up to about 300 f lay the cut HTV on the press for about 5-10 seconds, but DON'T press, the warmed up htv weeds easier. Instead of going for your final design, just cut a small circle or square at a time and weed it as a test until you hit the sweet spot. Maybe even use the cutters test cut function. Make sure the blade isn't sticking out too far from the holder. 1 Share this post Link to post Share on other sites
