keloholic 0 Posted May 11, 2015 My MH 721 Refine only will cut fine up until the carriage gets to the 9 inch incremental mark on the ruler. As it reaches the width of 9 inches it seems as if the pressure lets up and it stops cutting deep enough to make the cut. It only scratches the image on the surface of the vinyl. If I cut a small decal it is fine, but decals over 9 inches across won't cut after the 9th inch, just scratch. I have the blade as low as it will go without cutting through the backing from 1-9, but still only scratches the surface after the 9th inch. Pressure also set to maximum 600. Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted May 11, 2015 Make sure that the carriage head white wheels are firmly down in the track. Some times come off Make sure no cracks in carriage blade holder. Look in your carriage track and make it is clean.. Make sure nothing stuck to the white wheels. or that the white wheels aren't cracked or broken.. Something is keeping it from moving. Even take the carriage head cover off and watch it... Share this post Link to post Share on other sites
