ALICOLE2 1 Posted May 10, 2015 I have traced this image in sure cuts a lot but when I cut it it cuts the whole image it's not separating my colors. Can someone please help me redo it and color separate it for me. Share this post Link to post Share on other sites
ALICOLE2 1 Posted May 10, 2015 Picture might help sorry Share this post Link to post Share on other sites
dirtrocker 60 Posted May 10, 2015 Can you upload the file you are cutting from? Clarify, cause I may be missing something on how sure cuts a lot works, but are you cutting one color, then cutting another color or do you have a cutter with print capabilities? The others more familiar with sure cuts a lot may know something I don't. Share this post Link to post Share on other sites
TauntDevil 19 Posted May 10, 2015 Spent a minute or two on it. Nothing crazy but basically, next time, what you will need to do is when you trace one part, you will need to make a new layer (Ctrl + 1 in SCAL) and then make the next part. Before cutting, click the eye of the layers you dont want seen so they are no longer visible and only what you want cut, to be visible. Hope this helps. I traced the images quickly so probably not as accurate as you would like but if you open in SCAL and look at the layers, you can remove pink or white parts before cutting. Hope this helps. dingydobopdohop.svg 1 Share this post Link to post Share on other sites
30-284 86 Posted May 10, 2015 Using the file from devil, I just put registration marks on it. Just ungroup it, separate them and cut out of the different colors, Then use the registration marks to line the layers up. is this what you are asking about? Donn PD.svg 1 Share this post Link to post Share on other sites
ALICOLE2 1 Posted May 10, 2015 Thank you both very much!!!! 1 Share this post Link to post Share on other sites
