iam1ofhis 0 Posted May 1, 2015 I've begun to experiment with screen print transfers and am having mixed results. Some come out perfect. Some - not so much. Either the screen print doesn't come off completely or it applies but then lifts. Out of 14 shirts, I had issues with 6. Any idea on why this is happening? I'm using 385 degrees, 12 seconds, and medium pressure. Share this post Link to post Share on other sites
fustratedinhawaii 71 Posted May 1, 2015 Where are you buying the transfers from? I've heard some companies make good ones, while others...not so good...might be the cause. Share this post Link to post Share on other sites
jaybyrd 3,769 Posted May 1, 2015 Check your press temp. If you can't try jumping it 15 or 20 degrees and use a little more pressure. I used to think all transfers were junk until I realized my press was way off on temp Share this post Link to post Share on other sites
knucklehead 530 Posted May 1, 2015 Have you checked your temperature, all over the element? Some presses are way off from the digital readout, and section, to section, of the element too. Share this post Link to post Share on other sites
