showtimeDM 0 Posted April 6, 2015 Hi People, I've just recently purchased a Refine MH1351 plotter second hand from a friend's friend. Trying to get it to work at its full potentional. So far I've got it running on Windows 7 with SignCut Pro via USB2Serial and thats about it. Can't seem to make it work via normal com1 (serial) or ltp1 (printer) which comes out garbled as I'm trying to see if Flexisign works. I'd like to know what programs you use and what your OS/System setups are. Thanks in advance. Share this post Link to post Share on other sites
MZ SKEETER 4,709 Posted April 6, 2015 You state you are using a USB to serial connection..? If it is not a Tripplite Keyspan Adapter or a Belkin.(Those are brand names) It probably won't work... This is what you need, if your going that route. Here is cutter set up. . http://www.uscuttersupport.com/mh-series-vinyl-cutter-setup.html Share this post Link to post Share on other sites
showtimeDM 0 Posted April 6, 2015 Hi Mz Skeeter, Well the device is connected via usb however the driver recognises it as a com4 port (serial) not as a standard usb. I also do have a serial port on my computer which is an Intel Quadcore 2.4gz. That serial port won't work? Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted April 6, 2015 the reason it isn't recognized as a true usb device is it has a emulation chipset that is flaky at best to simulate a usb port - that is why you have to install the ftdi drivers to get it to communicate thru the chipset with any usb connection. you are much better using the serial connection in your computer than using the usb at all as long as you do have that on the computer you are using - you will just have to make sure to use a null modem serial cable as a standard serial cable wont work. remember the plotters do not work like printers so attempting to use it as one will never get you results you can use Share this post Link to post Share on other sites
