reeves1985 2 Posted April 4, 2015 I've had a creation pcut cto360 nearly a year and recently purchased the floor stand The problem is there was no instructions and I can't for the life of me get the thing together I have looked at the instructions online but they are too vague to help The cutter doesn't seem to want to line up with the bracket holes and the legs only seem to be able to fit one way Any help would be appreciated Oh and the cutter was purchased from ukcutter as well as the stand I sent pictures which they requested to make sure it was the correct stand for my machine Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted April 4, 2015 Maybe post some pictures of where you are at....or what you have.. UScutter is not the same as UKcutter. This is the stand set up manual from UScutter for Pcut. http://www.uscuttersupport.com/downloads/Support_PDF/CutterSetup/Pcut/Pcut_Stand_Guide.pdf Share this post Link to post Share on other sites
reeves1985 2 Posted April 4, 2015 <blockquote class='ipsBlockquote'data-author="Mz SKEETER" data-cid="390347" data-time="1428168642"><p> Maybe post some pictures of where you are at....or what you have.. UScutter is not the same as UKcutter. <br /> <br /> This is the stand set up manual from UScutter for Pcut. <br /> <br /> <a href='http://www.uscuttersupport.com/downloads/Support_PDF/CutterSetup/Pcut/Pcut_Stand_Guide.pdf'>http://www.uscuttersupport.com/downloads/Support_PDF/CutterSetup/Pcut/Pcut_Stand_Guide.pdf</a></p></blockquote> thanks I understand ukcutter is not uscutter I just hoped someone could help as I thought quite a few of these creation pcut were the same/similar etc I've looked at those instructions earlier but they didn't help much I'll put some pictures up later but as a general idea this is the point I have got to I have: the screws and locking washers etc 2 foot pieces with wheels attached The 2 side pieces (legs) with the 4 holes in the centerfield and 2 holes to one end the cutter mounting bracket 2 roller bars and 2 big silver round end pieces? Right the legs have a channel running top to bottom on both sides one is slightly different to the other (but both legs identical) these have four holes in the centre and 2 holes at one end (I'm not sure which way these go) and also which side the centre suppoDr is supposed to fit as it seems I can only get the centre section to fit one way The cutter mounting bracket again looking at the instructions and the way it goes on the top I just cannot get it to fit together I guess what I am really asking is does anyone have one on a stand and can show me how it fits together I should then be ok to assemble Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted April 4, 2015 what does your cutter look like? Is it red? White? There are several different styles/models Also have you checked youtube.com? Share this post Link to post Share on other sites
reeves1985 2 Posted April 4, 2015 It's red and black version the underside looks like this Share this post Link to post Share on other sites
reeves1985 2 Posted April 4, 2015 This is the cutter Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted April 4, 2015 those cutters were not sold on UScutter.com This is the list of cutters...The regular Pcut was white.. The original Pcut laser pointer was red.. Has not been sold on Uscutter for several years. . but is still different than what you have. And the current red cutter being sold is made by Liyu..... UKcutter should be able to help you with this.. http://start.uscutter.com/ Share this post Link to post Share on other sites
reeves1985 2 Posted April 4, 2015 Ok no problem worth a try though as their forum is dead and will have to wait until Tuesday for help Thanks anyway Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted April 4, 2015 You could try Creation also There is a user manual that includes stand set up for the CT model http://www.creation.com.hk/eng/support.asp http://www.creation.com.hk/eng/uploadfile/download/KINGCUT%20CT%20User%27s%20Manual%284.22%29.pdf Share this post Link to post Share on other sites
jaybyrd 3,770 Posted April 4, 2015 Looks a lot like my old laser point 1 Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted April 4, 2015 I remember my first pcut - I put the top brackets on the stand backwards and wondered why they didn't line up right Share this post Link to post Share on other sites
reeves1985 2 Posted April 4, 2015 I must admit it looks a lot like the laserpoint without the laser but that's about as far as my knowledge on that part goes I seem to have got somewhere by actually putting everything together backward starting from cutter mounting down as a test The thing that's got me scratching my head is the actual side legs have a channel either side and assume if figured out the right way around but the centre support only fits on one end and doesn't line up on the other unless you turn the leg upside down which will work fine bit I'll then have 2 holes on one side at the top and the other side will be at the bottom I think they should both be at the top because one lines up with the cutter mount bracket It's all a bit strange Share this post Link to post Share on other sites
skarekrow 1,842 Posted April 4, 2015 That is one long sentence, reeves.... Share this post Link to post Share on other sites
reeves1985 2 Posted April 4, 2015 That is one long sentence, reeves.... Oops sorry typing on the mobile doesn't do any good 1 Share this post Link to post Share on other sites
skarekrow 1,842 Posted April 4, 2015 Just funnin' ya... Share this post Link to post Share on other sites
mfatty500 454 Posted April 4, 2015 That is one long sentence, reeves.... Yeah, I'm outta breath reading that sumbitch... 1 Share this post Link to post Share on other sites
Jburns 239 Posted April 5, 2015 here is my Pcut and stand- hope these help: Share this post Link to post Share on other sites
reeves1985 2 Posted April 5, 2015 Yeah, I'm outta breath reading that sumbitch...Haha Well I've managed to get this son of a b***h up in some form although I am fairly certain the shop sent me one wrong leg as the only way it fits together is with one upside down. Won't cause an issue as the stand is as solid as it's ever going to be, but I'll be bringing it up with them. It looked like it may have been a demo/display one anyway as it was just slung in a box and there is numerous bolts that have no home and a few of the sizes were short, so seems to add up. Share this post Link to post Share on other sites
reeves1985 2 Posted April 5, 2015 here is my Pcut and stand- hope these help: [img=http://1.1.1.1/bmi/i768.photobucket.com/albums/xx326/Jasonburns01/photo%201%209.jpg] [img=http://1.1.1.1/bmi/i768.photobucket.com/albums/xx326/Jasonburns01/photo%202%206.jpg] [img=http://1.1.1.1/bmi/i768.photobucket.com/albums/xx326/Jasonburns01/photo%203%201_1.jpg] That's the stand I've been sent But my pcut looks like the laserpoint so not sure if it's the correct stand Also I notice the screws in the side of the legs holding the cutter bracket I had to turn one upside Dow to get the centre brace to fit Share this post Link to post Share on other sites
reeves1985 2 Posted April 5, 2015 In fact come to think of it they've definitely sent that stand and I'm sure it's wrong because wheree it mounts to the cutter, mine has like a square groove, which I assumed the mount slotted onto but it doesn't. Looking at the pic above that may be why as the white pcut is flat where the mount goes Share this post Link to post Share on other sites
Jburns 239 Posted April 5, 2015 my white plastic grooves look just like your red plastic grooves.- The mount Does Not slide into the plastic- I thought the same thing. the cutter simply sits on top. If you look closely you should have small holes for the screws to go into. Share this post Link to post Share on other sites
Sue2 920 Posted April 5, 2015 Looks a lot like my old laser point 1 That's exactly what I thought! Looks just like my Laserpoint I Sue2 Share this post Link to post Share on other sites
reeves1985 2 Posted April 5, 2015 my white plastic grooves look just like your red plastic grooves.- The mount Does Not slide into the plastic- I thought the same thing. the cutter simply sits on top. If you look closely you should have small holes for the screws to go into. I managed to figure that bit out after a good while head scratching!!. Can I ask did your centre support fit correctly? The two legs have 4 holes in the middle (for the centre brace) then there is 2 holes on one end which one hole lines up with the bracket I assume you screw them together I have had to turn one leg upside down though to get the centre brace to fit properly so now one one side I've got those two holes at the bottom near the feet! I'm to trying to work out if I have some how received a wrong leg as it looks like each one needs to be slightly different to fit with the shape of the centre brace Share this post Link to post Share on other sites
Jburns 239 Posted April 5, 2015 Hello - yes the center support fit correctly- here are some more pictures: the narrow channel must be on the inside: Outside Stand: INside Stand: Top of Stand: 1 Share this post Link to post Share on other sites
reeves1985 2 Posted April 5, 2015 Hello - yes the center support fit correctly- here are some more pictures: the narrow channel must be on the inside: Outside Stand: [img=http://i768.photobucket.com/albums/xx326/Jasonburns01/photo%202%207.jpg] INside Stand: [img=http://i768.photobucket.com/albums/xx326/Jasonburns01/photo%201%2011.jpg] Top of Stand: [img=http://i768.photobucket.com/albums/xx326/Jasonburns01/photo%2016_1.jpg] Thanks that was exactly my thought I must have been sent a wrong leg because when ivput the narrow channels correctly facing the inside. Only 2 of the screw holes line up on one side. The other side all four line up, so I can only assume whilst both legs look the same the are actually slightly different. On closer inspection it looks like those 4 holes as in your last picture are slightly offset in the narrow channel. So must be a specific side for each leg Will defina rely be taking this up with the supplier (ukcutter) Thanks for your help! Share this post Link to post Share on other sites
