Vinil The Kid 0 Posted April 3, 2015 downoaled the New version, Ver.2.2.881but it doesn't work, keeps on "Synch cutter" and the work goes to hold. I use Adobe Illustrator CC and 6 (in both cases doesn't work) Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted April 3, 2015 Graphtec is your tech support for Cutting master... And you should have the cutter on GP-GL command... Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted April 3, 2015 which cutter - did you double check which cutter and port is selected in the software?Welcome from the USA, Guadalajara Share this post Link to post Share on other sites
Vinil The Kid 0 Posted April 4, 2015 Erased the plug-in 3 times and installed the old one fix the problem... Thanks!! Share this post Link to post Share on other sites
lablover 218 Posted April 7, 2015 Erased the plug-in 3 times and installed the old one fix the problem... Thanks!! Too bad, the new version seems to have some nice upgrades.....I may give it a try as long as I can revert back if need be. Share this post Link to post Share on other sites
