ElectroJesus 1 Posted March 23, 2015 Anyone master cutting Siser ReflectAll? It's thicker than most of the other stuff and pretty pricey, i dont know to be wasteful going through a trial and error phase. Share this post Link to post Share on other sites
GraphxNMore 282 Posted March 23, 2015 I don't know about reflective, but for glitter HTV I have to extend blade a little and virtually double my pressure. That said, setting from one SC cutter such as mine will be different from another SC. I'm sure MH series cutters would be the same. Share this post Link to post Share on other sites
Wildgoose 4,200 Posted March 23, 2015 Every cutter and every product tends to differ even from roll to roll of the same stuff sometimes. You should have a test button that will do a small test cut. My old P-Cut you pushed the pause button twice and it cut a little box about 1" wide by 1/4" tall. It's better to waste a little at the start than cut a whole bunch and waste large pieces. I would draw a little box if you can't find any test feature on your cutter. Siser carriers will generally handle some over pressure without letting the blade go clear though to the strip. Share this post Link to post Share on other sites
ElectroJesus 1 Posted March 28, 2015 Thanks for the tips, I extended my blade some and cut some stars to test. So far so good. 1 Share this post Link to post Share on other sites
