lablover 218 Posted March 5, 2015 So, I've been getting top platen edge lines on my golf towels. Coastal recommends foam pad under towel smaller than platen so the edges don't hit the towel. Do I need any special foam or could I get something at like Hobby Lobby or Joanns? I could order it from coastal but I don't want to wait Thanks all Joe Share this post Link to post Share on other sites
Wildgoose 4,200 Posted March 5, 2015 There is a foam kit from Conde. I can't tell what kind of foam it is but there is a good sized roll and you cut your sizes from it. So far it seems to be able to withstand more than one use. I have only used it a a few times though so I don't have a good experience to pull from. 1 Share this post Link to post Share on other sites
MadHatterGraphix 1,258 Posted March 5, 2015 I had bought the foam kit from coastal to do t-shirts and it seems to be the same foam they use for air conditioner insulation around the windows. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 5, 2015 would just a press pillow work like we use for zippered items? Share this post Link to post Share on other sites
Ravenwind / One Off Grafx 187 Posted March 5, 2015 No I don't think you could use a standard foam from the hobby store. Unless it was able to withstand hi heat. I think it is a neoprene foam Share this post Link to post Share on other sites
knucklehead 530 Posted March 5, 2015 Is a neoprene mouse pad big enough? You can heat press them, with no damage. Share this post Link to post Share on other sites
jcart 11 Posted March 5, 2015 I use the green foam from Joanns. They have different thickness but the one I use is about 3/8". Works great with the heat. 1 Share this post Link to post Share on other sites
lablover 218 Posted March 5, 2015 Time to go check on some green foam. I also ordered the foam pads from Costal as well. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted March 5, 2015 ohhh while you are at it you might as well get the green rubber for glass and the nomex pad for tiles - make it an order 3 Share this post Link to post Share on other sites
OWJones 1,981 Posted March 6, 2015 ohhh while you are at it you might as well get the green rubber for glass and the nomex pad for tiles - make it an order 2 Share this post Link to post Share on other sites
lablover 218 Posted March 6, 2015 Hmmmm...Glasses....Sounds fun 1 Share this post Link to post Share on other sites
TT57 135 Posted March 10, 2015 I use the green foam from Joanns. They have different thickness but the one I use is about 3/8". Works great with the heat. jcart, can you post us a pic of the green foam you use. I have seen it at Joann's but wasn't sure it was heat proof Share this post Link to post Share on other sites
Phototec 1 Posted October 13, 2018 On 3/10/2015 at 3:31 AM, TT57 said: jcart, can you post us a pic of the green foam you use. I have seen it at Joann's but wasn't sure it was heat proof I purchased the green foam from JoAnn's and although it works for HTV transfers (300-320°), it does NOT work for Dye Sublimation, which is 400°. After pressing a garment with a Dye Sublimation and opening the heat press, the green foam had melted flat in a few places, so it's NOT heat resistant like the Vapor Kits advertise. 1 Share this post Link to post Share on other sites
darcshadow 1,625 Posted October 15, 2018 Even heat resistant stuff has a melting point. And did it say heat resistant on the package? The green foam I'm looking at online doesn't mention resistant, only fire retardant, meaning it won't burn easily. Share this post Link to post Share on other sites
