waynerp 0 Posted February 25, 2015 Hi All. I am a total newbie in vinyl cutters & plotters. To get an understanding of the software and hardware i have purchased a Creation PCut CT-630 My intention was to use it with a newer operating system with a USB cable, and have tried countless times and failed. So i am using an older PC with a parallel port running on Windows 7 32bit I understand that no drivers are needed with the parallel cable.. correct? The plotter came with Artcut software 2005 which i initially setup to test. The plotter worked fine with no problems, but the software is very limited, so after looking at some forums i have installed signblazer. I have been practising but when the plotter goes to cut, it goes through the motions but the blade does not come down to cut the shape / text. Its driving me crazy so i was hoping someone might be able to help out. i have read through the manual which doesnt really help me. Any suggestions much apppreciated thanks Wayne Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted February 25, 2015 thinking maybe your UK cutter might use a different chipset than the us version - try the roland pnc-1000 driver in signblazer and see if that cuts Share this post Link to post Share on other sites
waynerp 0 Posted February 25, 2015 Many thanks for your reply. Will give it a try now thanks Share this post Link to post Share on other sites
waynerp 0 Posted February 25, 2015 OK i tried using the roland driver and got no response from the plotter. Any other ideas much appreciated thanks Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted February 25, 2015 did your version of signblazer show that exact model of cutter or just the us version which is a slightly different model? Share this post Link to post Share on other sites
MZ SKEETER 4,708 Posted February 25, 2015 The version from Uscutter that I have downloaded has CT630 on it. And I got it from UScutter support. 1 Share this post Link to post Share on other sites
waynerp 0 Posted February 25, 2015 Hi Yes it has the CT630. I think it could be something else. i have just tried the plotter again with the artcut software, and the cutter/blade part isnt moving down as well, so i guess it might be that part that might be faulty. Weird as it was fine when i first tried it. is it common for that part to fail ? Share this post Link to post Share on other sites
waynerp 0 Posted March 1, 2015 Hi Do you know if it is likely that the blade part can fail, the part that moves up and down? many thanks Share this post Link to post Share on other sites
Balkiss1988 0 Posted June 18, 2015 Please i have pcut630 verry old but i have not nor cd logiciel nor cable parallèle you help me how does it work and what cable i buy and what their driver Share this post Link to post Share on other sites
Wildgoose 4,200 Posted June 18, 2015 Does it have a USB port? I ran my P-Cut successfully with a regular USB from a windows 7 computer. You are going to need some cutting software. Try downloading the free 7 day trial of SignCut Pro. They will have your machine in the system and at least you can get up and running and then decide what direction to go. There are some other options like the free Signblazer here on the forum but it is an older abandoned software and you might want to be sure everything is working before delving into something like that. Share this post Link to post Share on other sites
Dakotagrafx 7,297 Posted June 18, 2015 like goose said the usb worked for me with the addition of the ftdi drivers installed for that convresion chipset but that is for the US version - not sure which particular version you have in Tunisia Share this post Link to post Share on other sites
mickyd5182 0 Posted October 20, 2015 hi, ive just bought a cr630 PCUT ... it came with no drivers, i have tried downloading the drivers online but my laptop is not finding anything to do with the plotter, im new to this so it may be me but im lost and could do with some much needed advice please ? thank you so much Share this post Link to post Share on other sites
slice&dice 2,450 Posted October 21, 2015 hi, ive just bought a cr630 PCUT ... it came with no drivers, i have tried downloading the drivers online but my laptop is not finding anything to do with the plotter, im new to this so it may be me but im lost and could do with some much needed advice please ? thank you so much You started a new thread with this --- let's try to remain in that one, OK? http://forum.uscutter.com/index.php?/topic/50216-creation-cr630-drivers/?p=405916 Share this post Link to post Share on other sites
