dudesanddivas
Help.. my vinyl roll is getting wrinkled when feeding thru cut job
betting on too much blade  and making the plotter pull from a full roll - but without more info just a guess
Make sure the pinch rollers (spring-loaded pressure rollers) are sitting directly above the lower grit rollers.
There is a gap right in the middle of the grit rollers (marked with a sticker on the front of the carriage rail) --  make sure you don't place a spring roller in that spot.
Also, since you have the SC machine, see these postings describing a flaw in the engineering of that unit -
http://forum.uscutter.com/index.php?/topic/41547-need-help-with-newly-bought-sc-series/?p=323057
and
http://forum.uscutter.com/index.php?/topic/36439-liyu-sc-gets-up-and-running-my-1st-impressions/?p=283267
