ShowMeCleaning 53 Posted February 16, 2015 I have a work force 30. Using CorelDraw to print. It prints this little skinny line down and across my page. Thanks look forward to your reply Share this post Link to post Share on other sites
mr300s 1,272 Posted February 16, 2015 It might be Banding can you see it if you look at the image in wire frame? Share this post Link to post Share on other sites
OWJones 1,981 Posted February 16, 2015 And when you view your work in wireframe mode, those lines aren't there? Share this post Link to post Share on other sites
ShowMeCleaning 53 Posted February 16, 2015 Didn't see any thing in wireframe. Share this post Link to post Share on other sites
ShowMeCleaning 53 Posted February 16, 2015 Now I how 20 Koozies to do One side was green and the line was like a box around the first. Changed over to done the red no line. Share this post Link to post Share on other sites
ShowMeCleaning 53 Posted February 16, 2015 Yup its back on the red. Share this post Link to post Share on other sites
ShowMeCleaning 53 Posted February 20, 2015 I'm using Tex-R paper to print on and it prints lines. I'm doing mugs and also leaving black spot like there was ink on the paper but there was not. Little black spot show after heating. Share this post Link to post Share on other sites
jaybyrd 3,770 Posted February 20, 2015 Are you using spray glue or tape? I've had glue leave speckles all over if it didn't atomize properly. Only time I've had it is when I didn't clean the spray nozzle. Share this post Link to post Share on other sites
MadHatterGraphix 1,258 Posted February 22, 2015 If the banding shows simple solution is change the quality properties to either fine or higher. And under the more options tab uncheck high speed. Share this post Link to post Share on other sites
