ApeShirt 1 Posted February 10, 2015 Anyone cut sticky flock, for rhinestone use, with the US Cutter SC cutter? I had a supplier of the sticky flock say it won't cut it since the SC has a stepper motor. US Cuter says it will, however. Any real use feedback would be appreciated. Share this post Link to post Share on other sites
jaybyrd 3,769 Posted February 10, 2015 I know someone who cut it on an mh and if that'll cut it I'd say your SC should have no problem. 1 Share this post Link to post Share on other sites
30-284 86 Posted February 10, 2015 I have cut it with my copam and I know that works perfect. Just need to adjust the blade to extend out further than normal, I have a separate holder just for sticky flock. Donn 1 Share this post Link to post Share on other sites
xpaperman 719 Posted February 10, 2015 I have the SC and I cut Sticky Flock for rhinestones no problem! I don't know who told you it won't work but they are giving out bad information. You will (like with any cutter) have to adjust blade depth and pressure. Once you dial it in, make notes of your settings for future reference! Happy Stoning! 3 Share this post Link to post Share on other sites
ApeShirt 1 Posted February 11, 2015 Thank you so much. Guess it's time to take the jump into bling, lol. Well, other than glitter vinyl. Share this post Link to post Share on other sites
Sue2 904 Posted February 11, 2015 Glitter vinyl cut into little rhinestone size circles is a good imitation for real rhinestones...and sometimes faster! Here is a design I tucked away for future ideas/creations. My files are full of ideas...just have to find time to DO them. Sue2 2 Share this post Link to post Share on other sites
jaybyrd 3,769 Posted February 11, 2015 LoOKs good Sue. I toyed with doing that with deco sparkle a couple years ago but forgot all about it until you just posted the butterfly. Now that I have some real glitter I may try it again. Share this post Link to post Share on other sites
Sue2 904 Posted February 11, 2015 LooKs good Sue. I toyed with doing that with deco sparkle a couple years ago but forgot all about it until you just posted the butterfly. Now that I have some real glitter I may try it again. Jay, I didn't do that one...I saw it online and saved it in my idea file for future projects. But thought the glitter vinyl made a pretty good substitute for rhinestones. Sue2 Share this post Link to post Share on other sites
jaybyrd 3,769 Posted February 11, 2015 Correction on my part. Thanks to the mystery person on the internet, it looks great. Now back to our regularly scheduled chaos Share this post Link to post Share on other sites
ApeShirt 1 Posted February 11, 2015 Looks good Sue. I hate weeding glitter vinyl though. That looks like it would take a bit of time to weed. 1 Share this post Link to post Share on other sites
djque 246 Posted February 12, 2015 Looks good Sue. I hate weeding glitter vinyl though. That looks like it would take a bit of time to weed. its actually easy to weed and fast all in one piece I make glitter rhinestones a lot. to the OP when cutting sticky flock I would have a xtra blade and blade holder just for it and flock and glitter and do 2 passes also make sure that your blade is a 60* blade and not 45*. when you cut sticky flock right it will leave the cut circles on the paper. I use to use a MH721 to cut it and was at like 180 to 200 pressure. also you might have to cut your circle 1 size up. do small test cuts. 3 Share this post Link to post Share on other sites
iam1ofhis 0 Posted April 15, 2015 What pressure and speed are you using on your SC with the Sticky Flock? Share this post Link to post Share on other sites
jakesspts 0 Posted April 23, 2015 Is there a video tutorial how to set up to cut sticky flock with sign cut? Share this post Link to post Share on other sites
GraphxNMore 282 Posted April 24, 2015 Add pressure and blade, speed around 200, and muticut on 2. No worries. Cut them regularly with my SC. Just check blade holder after each template for debitage. It'll gum up the works. 1 Share this post Link to post Share on other sites
iam1ofhis 0 Posted June 9, 2015 Easy, What pressure do you use for the SC? Share this post Link to post Share on other sites
djque 246 Posted June 9, 2015 look like he/she said speed around 200 but I remember cutting at 180 to 200 on a mh721. you can set the speed to how fast you want it cut. on my graphtec my speed is 14 Share this post Link to post Share on other sites
GraphxNMore 282 Posted June 10, 2015 Around 200on pressure as well. Share this post Link to post Share on other sites
OWJones 1,981 Posted June 12, 2015 The only issue I could think of with stepper motors would be in precision at small sizes. SS6 stones are only about 2mm in diameter, and cutting perfect 2mm circles may be beyond the capacity of a cheap, stepper motor cutter. Only way to find out for sure is to try it. Be sure to report back and let us know! Share this post Link to post Share on other sites
