arty-rc 719 Posted February 9, 2015 I've been doing sublimation name badges and my Ricoh printer has been acting up. When I print out my picture/text on the left side of the paper, the result is a slightly misalignment of the print. When I move the same picture/text over to the right side of the paper it prints perfectly. This has been happening on my last 4-5 printings. I have done the print head alignment, head cleaning, nozzle check etc. I have resorted to printing only on the right side of my page and then turning it around to print on the now second right side. Anyone have a clue as to my problem? Thanks. Share this post Link to post Share on other sites
mr300s 1,272 Posted February 9, 2015 Are you using Corel What if you draw your box around it then hit group then align and center? Or am I missing something Share this post Link to post Share on other sites
arty-rc 719 Posted February 10, 2015 I'm using Corel x6 and everything lines up properly. I double check everything at 200 percent magnification to make sure. The problem is in the printing.The graphic has a slight blank area on the left side of the furthest part of it while the right side is perfect. It looks somewhat like a misalignment of the printer heads. I did print out another badge late last night and it printed properly. Just for kicks I printed it a second time on the left side and it also printed properly. Go figure!! I will try the group and align and center feature anyway to see how that works. I'll let you know what happens.Thanks. Share this post Link to post Share on other sites
mr300s 1,272 Posted February 10, 2015 OK Good Luck maybe it was just having a bad ink day Share this post Link to post Share on other sites
jaybyrd 3,770 Posted February 10, 2015 I had an issue like that with my 3300 once and when I printed from another program it was fine. Only did it in corel and if memory serves I had to reinstall corel to fix it. Share this post Link to post Share on other sites
arty-rc 719 Posted February 12, 2015 Update. I tried again using my laptop Corel program and got the same results. I tried a different graphic and got the same results. I even changed cables. My next step will be calling the store where I bought the printer. Share this post Link to post Share on other sites
mr300s 1,272 Posted February 12, 2015 Todd will get you goig. I was just in there today speaking with him and picking up some stuff... Share this post Link to post Share on other sites
