Appleuser
Graphtec CE6000-60 Firmware
Hi!
Few days ago I upgraded the firmware on my CE6000-60 machine. Firmware version 2.00 Since that upgrade, I have ruined almost every job I make.
I must do it maby 3 times to have it cut ok.
I get often these error messages
E01006 HARDWARE ADDRESS LOAD ERROR 76013627 H (The last digits changes everytime)
Never had this issue on the previous firmwares.
Tried to contact graphtec, but they told me the material do not cover the sensor. So I must make sure to have covered this sensor.
But my material do cover the sensor when cutting. I always make sure of it..
Is there anyway to downgrade this firmware to 1.80 or 1.90?
It was more stable.
regards
C
part of the reason I quit doing firmware upgrades unless there is a real need - if it bails part way thru sometimes the only option is to send the cutter in to get it fixed.  not saying that is the case this time but I look at it as if the risk is worth the reward and if my cutter is working properly it usually isn't worth the risk to me
I have only upgraded 1 time since bought new   2008,,because it had an upgrade then.., My cutter has run great,  never needed an upgrade...Why change it?
  • Like 3
After I successfully cut a job. and I do nothing. The vinyl is in the machine, I often get this message
E01001 HARDWARE ILLEGAL CODE BC04BF38 H
strange
YES, they say the latest version is ok.
I have even tried on 3 different windows machines and 1 mac. Get the same error message.
Never had this problem with the 1.80 firmware.
I am loosing money with this problem. I must cut 5-6 times to get 1 job without any problems.
sometimes I press "fast" and "arrow down" I get the error message. The cutter also power off/on in the middle in jobs.
I understand this is not the same model, But I found a service manual for the  FC8000..  and most errors are alike...with Graphtec  cutters.
I found this error that you posted above.  Table of Graphtec error messages.
http://www.graphteccorp.com/support/manuals/FC8000/FC8000UM2510.pdf
Page 101.  8.4
This error    for E01006 HARDWARE ADDRESS LOAD ERROR 76013627 H   on the FC8000  models,  It says Main board is defective
This code   E01001 HARDWARE ILLEGAL CODE BC04BF38 H   is also Main board defective.
Have you contacted and asked Graphtec what these codes mean for your CE6000?
Graphtec said that I must contact support locally. Where I live.
Contacted them and they said the machine must be sent to them to check and it will cost me $$$ :(
even it is within the warranty. Used the machine for 10 month.
Hi!
It was more stable.
regards
C
if it aint broke - break it with new firmware!  again why I leave it alone if if is working properly
  • Like 3
good maybe you are getting somewhere I wasnt happy to see they that pulled that on you.  You cant beat the Graphtec but now I am wondering about the part where they stand behind you a little??
Finally, I have gone back to firmware 1.80 :D
Now some testing..
How did you go back to a lower update firmware?  Might help others...Glad your getting somewhere....
Hi!
Download the firmware 2.00, 1.90 or 1.80 and and choose the firmware you want.
NB : Dont press "print" yet
On the cutter/plotter
1. Load the media ether of a roll or a sheet in the cutter/plotter.
2. Press the RIGHT ARROW key and the LEFT ARROW key simultaneously while the power of the cutter/plotter is turned on.
The following message is displayed in the LCD -->   " PLEASE SEND PRG. "
Then press "PRINT" on the software and the software will send the firmware to the cutter.
When it is finished, the LCD display  "xxxKB COMPLETED " and it restarts.
My cutter still has some issues after the downgrade. And maby I will get an mainboard replacement...
Well, after I have downgraded to Firmware 1.80 I get no more random errors like I did with the 2.00 firmware.
BUT sometimes it cuts random lines al over the job and ruin the work :(
Any ideas?
I just started cutting with a 6000-60, and I'll have to look tomorrow what the firmware is, but I haven't had any issues as of yet. I'll let you know.
